The Worlds Biggest Eye Contact Experiment - Montreal Quebec Canada
Event:  The Worlds Biggest Eye Contact Experiment - Montreal  Quebec  Canada
Back to basics, back to Love, Light & Equality in Montreal & around the World. It's Human Connection time!
"Let's share a minutes eye contact with strangers in public to rebuild our sense of shared humanity in cities all over the world!" - The Liberators International
