Have you ever wondered what this label is used for? It shows up not just on Fujifilm camera bodies, but on ones made by other manufacturers as well.
This label tells you the line where the sensor is inside the body. If you have ever tried to attach your camera body to a birding scope or telescope or something other than a regular camera lens, you run into an issue of getting it to focus. Some of those instruments tell you they have a certain distance (called back-focus) behind the last "lens" element where the image is actually projected. You then need to add in extension tubes of one kind or another between the "lens" and the camera body to get the projected image onto the sensor. But you need to know where the sensor is to be able to measure the distance correctly. This label tells you the line where the sensor is in the body.
    • I have the x-t5 and the H1 too but only with the X-T5 it happens what you has told. I discovered that if you set the Af-s the problem disappears. Only with the af-c with a half -press on the shutter button reveals tha maximum iso, otherwise with set the af-s it is shown the iso measured by the camera.
    • Found the simple answer to my own question. Having assigned Auto ISO to the rear dial, I only have to push in the dial to make the Auto ISO options appear, then turn the dial to choose. Nice and fast.
    • Hello All, I am returning to photography after a decades-long hiatus that was prompted by my loss of access to a darkroom. Digital rendered that excuse moot, so I now return with a recently purchased XT5. I am from the Hudson River Valley in New York where I have spent the past five decades engaged in environmental work, mostly on the Hudson. I teach at Pace University where I direct the Gale Epstein Center for Technology, Policy and the Environment. My project ahead is documenting the unseen Hudson, a combination of the obscure, under-appreciated, and invisible - a street-style approach to people, places and things that make the river what it is. There will be little landscape, if any. The "Mighty Hudson" is well-documented. If nothing else, it will be a mission-driven project to bring me back to photography while learning my camera. I look forward to everything this amazing site can teach me. Cronin
    • Hi,   I would really appreciate if someone could answer this question. Is it possible to have the X-T4 shoot in AF-S for photo mode and AF-C in video mode while the front lever is left at AF-S?  If so, how would this be done or wher in the menu system would I set this up? This is similare to setting the apeture at f/2.8 for photo mode but fioming at f/4 in video which I already have setup. Thanks and kind regards
    • According to the manual you can assign auto ISO to any one of the function buttons but I've never tried it. (It's not something I frequently change so all my function buttons do other things.)
