I'm using my XT2 with the 18-135 lens to shoot some studio video. I have set the focus and switched to manual focus but the lens continues to hunt. I have searched the internet and can only find that this can be controlled on the XT3 by switching the AF lock button to on/off. Any suggestions to switch off AF properly. I am shooting by myself so holding down the AF lock button is not an option.
