Anyone using the 16-80 on an X-E series camera?
I generally shoot landscape and use an X-T3 with 10-24 / 16-55 / 40-140 and the 33 f1.4.
with my X-E3 as my daily camera, only the 33 f1.4 feels reasonable on the body and I've used the 18-55 and thought it felt good, but would appreciate a little more reach.
I'm interested in the 16-80 for general use but worry about the lens weight.
Anyone use this combo and care to share?
    • Typically you need to make sure the lens is compatible with the camera, i.e. check the lens compatibility charts for your camera, then make sure the respective firmwares are updated o make sure older issues are resolved. After that, each lens has a manufacturer’s profile which will be embedded into the raw file meta data for the images captured using that lens. From there, it is up to the raw conversion software  to apply the lens correction to the image. Different converters do that differently, some automatically, some only if a setting is turned on. For in-camera jpegs, the on-board converter does the corrections automatically, assuming the camera recognizes the lens, it applies a generic profile otherwise. I do not know if that can be turned off or not.
