Hi guys, anyone with an X-E4 able to help me? I just received my X-E4 and the battery door doesn't sit totally snug when closed. There is some travel which causes some rattle when ever it's touched or placed down. It's pretty irritating, and though I could place something in the battery compartment (thin tape or something) to make it snug, I wonder if I got a bad copy, or if it is common with every X-E4. I read on 50-50 travelog that he had the same issue... can anyone help me out? Is this normal or should I call to complain to Adorama about getting a problem copy.
