Hello all....new to Fuji and to this forum.  I realize that Fuji has an app that allows for remote shutter release, but I have found the app to be glitchy.  I'm accustomed to the convenience of a wireless remote used frequently with my Canon setup, and am curious as to feedback from those using a wireless remote as to which remote you would recommend for an XT4?  Any constructive feedback would be greatly appreciated.  Thanks!
Edited by Rockitman
The app for the release works fine, the only issue i have with it, is that you have to hold your finger on the button constantly, instead of pressing once to start and once to end.
So that is my only issue with it.
The app itself isn't perfect, but the shutter release has always been 100% for me.
