Running into an issue where I'm able to use my X-T3 as a webcam in various apps, but the Fujifilm Webcam App does not detect my camera and I cannot adjust any of the settings.
Firmware in camera, webcam software, and OS on M1 Macbook Pro are all up to date.
All settings are set according to recommendations.
Anybody know of a solution for getting the app to detect the camera?
