On my 100S when I use the Menu button and say change a shooting setting, go back to take some images and press the menu button again, I return to the last used menu option.
Does this work for the GFX 50R????
Solved: "The format menu can also be displayed by pressing the centre of the rear command dial while pressing and holding the trash button." . there must be files on the cards I think for this to work.
