Hi all
I updated my x-t30 with the latest 1.40 firmware and connected it to my Win 10 PC.  Running X-Webcam, the camera is recognised ok. If I take a still shot the image is downloaded to a 'still' folder. Great! But I can't get an actual live image on the screen with the Windows Camera app. It refuses to recognise that I have a camera connected :(. As far as I can make out all the permissions are set ok. If I connect an actual Web Cam then that works fine in the Camera App. I'm obviously missing something with the Fuji? I have it set to X-Webcam in the Connections menu. Any ideas / suggestions?
Thanks
Louise
I made some progress though it doesn't appear to quite do what I want it to. I can't get it to work in Microsoft Camera but it will work in Skype. Although I can take a still pic which it puts in the 'Still' folder, that's all it will let me do - just one pic! If I try and take another, the shutter fires and a second pic isn't downloaded from the camera. Huh? I can't see that's intentional behaviour? Maybe connecting via a different Window's app would work better? Any recommendations?  Also, it appears to delete the contents of the Still folder when you disconnect - tut! Stills aren't stored on the SD card either - I presume with the X-Webcam connection mode, the SD Card isn't visible. Is this the same with other X-Webcam compatible cameras?
3 hours ago, jerryy said:
Keep going! It reads like you are making progress, some others are posting messages to the effect that they have not gotten as far as you did.
Hiya
It's just not very good, really. Calling it 'webcam' is misleading as it only works with streaming software like Skype, Zoom etc. You can't change many settings when it's running. You have to disconnect it to switch it off - just turning the camera off doesn't stop it working! Then you have to change the connection settings to use the normal usb again. So I think I'm abandoning it and going back to just using the hdmi output. Maybe a future firmware release will confer proper usb tethering - fingers crossed!
Louise
