Hi,
I have a problem with autofocus in my camera X-H1, even when I change to manual focus it is still autofocusing and turning the fucus ring on the lens doesn't change anything. The lens I use is Fiji 18-135mm f 3.5 and there is no manual clutch on this lens. Did anyone have that problem before?
