Have been using a remote shutter box on my XT30. Its a Product from the far east named "Shoot"an equivalent to the Fuji RR-100. It has worked without issue for some considerable time. Its fitted with a 2.5mm jack for the XT30.
I bought a simple 2.5 mm to 3.5mm adaptor so I may use it on my XT-3.    It doesnt work - are there any menu items Ive missed that need to be reset ??
I dont remember having to do anything with menus my XT30 and can find no info on Fuji Websites.  On researching the Fuji RR-100 remote shutter box, the equivalent of my " Shoot",I get conflicting information regarding the jack on the RR-100. Fuji says its 2.5mm but my XT-3 is well and truely fitted with a 3.5mm socket - no mention of an adaptor unit or cable.. The internal wiring of the "Shoot"
remote is simple, switching tip and mid ring to body via a two pressure level switch.
Any guidance appreciated
On my XT30, Movie Menu 4/4 between audio setting and time code setting lies the MIC/REMOTE setting.
On my XT3 Movie menu 4/5 between audio setting and timecode setting there is NO MIC/REMOTE setting.
Where have FUJI hidden it
Anyone using an XT3 with an RR100 remote shutter control ?
Well Ive got to the bottom of this. The XT3 is not the same as other Fiji cameras I have or have owned.
There is a little rectangular  panel above the card slots Door which has a dedicated socket for remote shutter with a 2.5mm socket.
I should have delved into the manual rather than trace solutions on the net and interogate the menus.
Hope this helps someone
