Hello,
I would like to understand a bit more deeply about using flashlights.
I've got a Godox TT685 on my camera or triggered with a Xpro. I also have a couple of manual Yongnuo YN660 I'd like to use not to let them gather dust on the shelf. In order to do that, I set them as slave, so they will flash when the sensor will trigger them.
When I get over the maximum speed sync of 1/250 on my X-T3, the Yongnuo won't flash, either in S1 and S2 (the Yongnuo), both in TTL and manual modes (the Godox).
Could anyone explain why?
Many thanks in advance.
