XF 18mm f/2
By Sandro_gsp · Posted
the "clean" command is enough ( and it takes few seconds) . I think I know what happens : every SD card and every cf-express card , come formatted by the factory. Reformatting them is not enough : the partition table is kept. Most probably the partition table (the first sectors of a disk or Usb card) are prepared by the factory in a way not always accepted by windows. The diskpart "clean" command simply remove all partition information, so that when you format the card again, a new partition table is created, compatible with windows. -
I found out how to defeat that, now to see if I get better results.
I thought it might be something like that. I think something else MAY be going on as well. Am going to experiment.
By Steve Crook · Posted
I upgraded to 4.3.0 and bluetooth broke, downloaded 4.3.1 and upgraded via SD card and bluetooth continued to be broken.
