I don't know about the X-T10, but in general for the Fuji cameras I('ve) own(ed), in MF setting they seem pretty accurate but in AF setting they can be way off for some reason. For AF I've therefore switched it off on both my Fuji cameras. The white marker in the distance scale shows the measured distance and the blue bars show the focus depth given the aperture. Esp. that latter part is not very accurate.
