Fuji X Shooters:
I'm looking to buy a Camranger 2.  However, their website tells me that they don't support the Record Video feature for Fuji cameras.  I'm curious as to whether -- without recording -- you can still monitor video being rccorded internally or more importantly output via HDMI in their app with focus peaking and change focus?
Thanks in advance for you help!
-- B.
