Sure I’m going to hear something about this one.  Am I missing a particular setting along the way when wanting to use face and eye detection?  I can’t for the life of me get this to show on the Xt-4 screen when shooting my daughter.
Do you have it turned on in the menu?
http://fujifilm-dsc.com/en/manual/x-t4/menu_shooting/af_mf_setting/index.html#face_eye_detection_setting
