I have a new X-T4 and X-Pro2 ... I have tried using the new Fuji iPhone app to download photos and use the remote.
i succeed once, downloading a few photos but then it froze. I tried deleting the app and reinstalling, this worked for download of a firmware upgrade and to use the remote, then froze, couldn’t get photos to download...
any advice out there, it’s a bit frustrating having to delete/reinstall to get it to work!
