I've just picked up a used X-T20 from mpb.com.  I noticed that attaching / detaching lenses is rather tight -- I have to get a good hold on the lens, or else it won't go, or I end up spinning the aperture ring or one of the other rings.
Has anyone else experienced this.  Does it loosen up over time?
My used X-T2 and X-E2S are both much smoother, especially the X-T2.
Quote
On 7/24/2020 at 11:43 AM, mawz said:
Yes, it will loosen over time. There is a small spring under each lobe of the bayonet which holds things tight, that spring will weaken and smooth out with usage.
Thanks for the response.   That's a relief.  Just to clarify... it's so tight right now, that I have to grip a lens (35 f2 size, for example) tight with 1 hand and the camera tight with another, and I end up spinning the rings un
Thanks, Mawz, very helpful.   That info helped me decide to keep the (barely) used x-t20 I bought online.
