Candid Portraits - Fuji X-T3 & Fujinon XF 56mm F1.2 R Lens
A great combo kit as well as a commanding portrait lens!
Noah in the Office by Din Dayemi, on Flickr
Mark in the Market by Din Dayemi, on Flickr
