Hi guys, new Fuji-freak here!
I bought yesterday X-T3 with the 18-55 lens and XF 50-140mm f2.8, both used.
At first I was really impressed with both of them but soon I figured out that there's something strange with the 50-140 and autofocus. The problem occurs at the maximum 140mm focal lenght. The autofocus can't focus near. It will only work for longer distances (over 4-5 meters) even though the minimum focus distance should be 1 meter. Even a slight zoom out e.g. 138mm will make the autofocus work normally.
All the settings are in "auto", I'm shooting in single shot mode and autofocus on single point. The problem occurs in every possible setup. Here's a video about the problem (I didn't find my stand so I had to use chair) [ignore the cat meowing] https://youtu.be/g8snv-60DBM
Has anyone else had the same problem or should I return the lens?
Edited by jufoso
  • 2 years later...
Hey,
So the YouTube video is no longer available. However, I do have a simular issue with ny 50-140 lens at 140mm. In Manual focus, during video recording, it seems the focus is sort of pulsing at times which can ruin that part of a video. I am not sure what causes the issue but, I have reached out to Fuji in hopes they can help. I will try to remember to update here if/when I hear back!
Did you by chance solve you issue @jufoso?
On 6/12/2022 at 9:31 AM, Leicht said:
Hey,
I have the same problem. Did you find and solution? @Leicht
  • 11 months later...
