XT3 on my Zhiyun Crane M2 compatibility help
The X-T5 is fine for that sort of use with the current firmware, use it in AF-S and either a single AF point or a small zone. It's in AF-C that the issues are more apparent.
I'm torn between a Nikon Zf, Nikon Z5ii, and an XT-5 because all fall in similar price range. I'm gravitating towards the XT-5 for the form factor and lens choices, but the autofocus issues I keep hearing is holding me back. So would like to know more from real users on your experiences? My use case: Street, and Landscape photography.
By Hillsidebeer · Posted
I've just taken my new GFX100RF on a week's holiday. I had the camera set to record both JPG and RAW images and to duplicate these on the two SD cards. On returning home, I downloaded the images and found that there were big gaps in the numbering. In general, the gaps seem to occur between days of shooting: Day 1: DSCF0110-0146; Days 2&3: DSCF0219-0301; Days 3&4: DSCF0538-0628; Day 5: DSCF0840-0915; Day 6: DSCF1201-1231 What's going on? I was expecting the numbering to be more or less contiguous. I may have deleted a few shots in-camera, but not large numbers in blocks. Thanks, Andy -
You could try to toggle the switch multiple times to get rid of dirt or oxidation on the contacts. But since it’s quite a new camera it’s more likely the switch is broken. Too bad
By WillBishop · Posted
Bugger no luck... looks like it's off for repair
