I think you're asking about the cover that protects the contacts in the body when the grip is removed. In that case "Yes, the cover that protects the contacts on the X-H1 is the same as the cover on the X-T2".  Although I've seen a listing for a kit for the X-H1 that includes that cover, a PC socket cover, and one or two other items. My local dealer (in Canada) couldn't find a listing for the X-H1, ordered a pack for the X-T2 and it was great. It included a PC socket cover, a door and two of the soft inserts that cover the contacts in the body and the slide-in cover for the flash. The kit for the X-T3 is CVR-XT3 and will work just fine for you.
