I am new to Fujifilm mirrorless camera.
I have been using Panasonic and Olympus m4/3 gears.
The GH5 10bit 4:2:2 is very attractive but the XH1 APS-C IBIS is perhaps the best of both worlds.
My only hesitation is the XH1 capable of recording 4K 8bit 4:2:0 only.
I was told that the Eterna mode recorded  video footage doesn’t  need colour grading. Is it true?
If it is true then I can use the footage for vfx green screen.
Any input?
Edited by Larry
Welcome to Fuji! I would say first, Eterna color grade is a specific look. If you want a low contrast flat tone it is very nice. If you nail the white balance can be very easy to work with in post for video. If you use a green screen and want to color grade I would suggest grabbing  an Atmos Ninja V to get 4:2:2 8 Bit output.
