I had taken over ten thousand JPEGS on the XQ2, and then switched to the XQ1,, latter, now at 8K in count. To me these are the best Fujifilm cameras over the SONY R100-m2/m3 which I seldom use...for the weight. While the XQ2 or XQ1 is always with me....anywhere, any time...really great low light exposures.
