Does anyone know of a good sportscasing for surf photography using the X-T1? WIth the new firmware and the my 10-24, I'm ready to take the camera into the water. I do however need a good casing and only divers seem to be catered to at the moment  :(
There is kind of a thread already going on this over here (http://www.fuji-x-forum.com/topic/77-underwater-housing-or-bags/).  Might look there at what folks are saying...
