Fujifilm X-T30 The Fujifilm X-T30 has just been registered online under the codename FF180006. It has bluetooth 4.2 like the Fujifilm X-T3. You can find the registration, spotted by nokishita, here. Well, actually neither Nokishita, nor the official registration, mention the…
The post Fujifilm X-T30 Registered Online and Coming Soon appeared first on Fuji Rumors.
Full Article on Fuji Rumors
If it has f-log and slow motion FHD, I will buy it,  otherwise not. It will rather have Eterna and AF from X-T3.
I suppose there will be huge competition in 2019 also in this segment of cameras, therefore Fuji should put in X-T30 also 4K60p, otherwise in late 2019 it will be just so so camera.
I am really exicting about Z6 that is getting ProRes RAW 12 bit. If there is no crop it will be really amazing.
Hope X-T30 will also be exicting.
Edited by renes
xxx
