Hi all, just taken some shots in RAW+JPEG with the wide conversion lens setting on by mistake. I've tried to reprocess in camera, but there's no option to change the setting in the in-camera raw processing engine. If I export to Lightroom I'm pretty certain that the wide conversion changes will be automatically applied and I'm not sure how to disable this. Seems like something you should be able to do in-camera.
Does anyone have an easy solution?
