Hi to everybody. A month ago I ordered from Aliexpress new lens called Kamlan f1.1. 50mm. It has come today, I was happy, it feet perfect. But unfortunately the shutter is not working with this lens. Is anybody advice me how to fix problem. Please, guys, help me. Thank you all in advance.
