lens recomendation (photographing commercial shooting)
I use this lens on my X-T2 as a good "walk-around" lens with it's wide range. Certainly have had no complaints on picture quality, and the weather resistant and OIS is great for this. Not sure how it would stand up to picture quality requirements for shooting a commercial. The 50-140 might be a higher quality choice in a zoom.
How long do you need to get?
