Setting my X-T2 for overhead shots, I thought I could use the App to control the camera. But with the manual focus switched in, it was still hunting.
Has anyone else had experience with this, is there a work around, or should I buy the Adobe tethering Pro plugin and try to control the camera via that??
Frustrating :(
