Hi,
is there any way other way how to switch back to movie AF mode called "Multi" once you touch display than digging into the menu? Is there any way how to toggle between movie AF modes while recording?
I love multi AF mode in 4k video, who needs face detection with that? But once in the while i need to tell to camera where is my subject of interest or do some focus pulling. So i touch the display and movie AF mode is switched to AREA. There is no way how to switch back to MULTI while recording?
Thanks for your reactions!
Best Regards,
Miloslav Stibor
