I'm looking to get into some manual focus lens and have always been interested in the Jupiter's. I'd like to buy a Jupiter 11 135mm f/4 lens but was hoping to get some insight on how to mount it and still be able to focus correctly? The lens is listed as having an M39 mount. What adapters/modifications would need to be made to allow this to work correctly?
Thanks in advance for any advice!
I have that lens.  Bought it when I was playing around with film.  I have mounted it to my XT-2 with an adaptor I bought on ebay.  Have no idea who I bought it from it was several years ago but the adaptors are very simple devices - no magic to them. The only marking on mine says L39-FX.  It works fine on the XT-2; if you set manual mode, you have the focus assist features available.  Compared to the 55-200 at 135, the Jupiter lens is pretty soft.  It is pretty small and light-weight, so it does have that going for it.
I agree with Arthur. The Russian lenses are soft and lens copies have wide variance in quality, chromatic aberration, ghosting, distortion and sharpness. Most of these lenses are sold from Russia, Ukraine and Belarus.Two popular Russian lenses are the Helios 44M 58mm f2 (swirly bokeh), and the MIR-1B 35mm. The Jupiter 9 is 85mm and has 15 aperture blades but lens copies have a lot of variance.
If you want to experiment with some vintage lenses you could probably get some sweet deals on Takumar M42.
The Auto Chinon 55mm f2, Rikenon 58 f2 and Nikkor non-AI 58mm 1.2   produce nice soap bubble bokeh.
As for mounting, you could always get and M39-FX adapter from Rainbow Imaging for less than $15.00
If you want to see the characteristics of different lens, just go on Flickr, search the lens you are interested in and view some of the pictures.
Hope this helped.
    • Just spotted this post on dpreview (https://www.dpreview.com/forums/thread/4764491) that describes an identical problem with the GFX100 II. Given that this issue was reported to Fuji in June 2024, I'm not expecting a new firmware for the GFX100RF to resolve it any time soon.
    • Either your camera or lens is defective or you could be setting something incorrectly.  What level of experience do you have with photography?  ILC cameras like an XT5 assume the operator is skilled, and the settings allow for a wide variety of choices. If you aren't familiar with settings and modes, it's quite easy to take bad photos with a good camera. You should become familiar with your camera before accepting paid work.  For example, one setting is Focus Priority vs Release Priority. When set for release priority, the camera will take a photo as soon as you press the button. If it's set to focus priority, the camera will not function the shutter until focus is confirmed. If you set AF+MF to ON, then you get release priority, even if the camera is set to focus priority. There are many other modes that affect how the autofocus behaves. Continuous vs single vs manual mode, face detection, pet detection, etc.  Another problem is if your shutter speed is too slow, the image will appear blurry even if it is focused correctly.  If the ISO is too high, the image will be blurry even if everything else is correct. If you choose the wrong aperture, your images can be blurry.  For one of your images that is "bad", maybe post it here with EXIF data so we can offer advice?   Also, maybe watch this video
    • X-T5 is a very good camera, I don’t have any issues with it and it takes great images. I would not change it for anything else that is available now, for me it works just fine. Fuji lenses are fantastic lenses. What FW version are you on ?
    • Glad to hear the light coming in from the left is just what gets around the lens cap. I think lens caps are just for protecting the lens, and don't promise to achieve total darkness for experiments or whatever else.   As to bad pixels, well, I don't know. I kind of ignore the issue and hope the camera is managing to hide them from me, as otherwise it's just going to make me mad not being able to fix them. I'd be interested to hear how expensive it is to "fix" them (meaning replace the sensor). Also, I think of them as something that only happens during sensor manufacture, but I wonder if there's anything the user does that influences having more or fewer of them.
    • Here is what works for me, on my X-S20: Before connecting the USB cable, put the vamera in Vlog mode and select Auto Power Off to "OFF" in the Power Settings menu. Then turn off the camera, connect the USB cable, and turn it on. I am using the Fujifilm X webcam driver that can be downloaded from https://www.fujifilm-x.com/products/software. Note that putting the camera in any other mode than Vlog, or setting Auto Power Off to anything other than OFF, will cause the camera to power off automatically after a while. This is a more than questionable design choice for Fuji - not to call it a bug - as nobody in their right mind would expect a webcam to automatically power off while being used. Remember to set Auto Power Off back to your favorite choice once you are done using it as a webcam. Another thing to keep in mind is that the camera seems to be drawing power from its battery, rather than the USB port, while being used as a webcam. This is not documented in the owner's manual. So I strongly recommend you use a dummy battery with an AC adapter instead of the battery.
