Hello,
I want to remote trigger the X-E3 - but not within the USB-Port. Has anyone the circuit fpor the 2,5mm socket? The default Canon wirering does not work stable. Some wires work, some not. I want to know the difference, because I want to build a multi-trigger.
Thank you and best gerads
Arlekin
