Hi Fuji experts!  Question on the X100.... My X100 is set to aperture priority (shutter dial at "A") and auto ISO. My question is why is it that auto ISO only allows me to set a maximum of 3200 ISO? I do not even have the 6400 ISO choice if set at auto ISO.
Only if I set auto ISO to OFF then I can choose 6400.  Thanks.
Everydayfuji
