When I choose LCD Only on my X-T20 I take my images using the LCD but when I want to review the images I have taken using the Play button, the images only appears in the EVF... To make it even stranger, it does not happen all the time. While writing this post it suddenly works as expected...
Anyone else with this bug?
If in LCD Only, press Play to view image. Check to see the EVF if it turns on when putting your eye up to it. If not, all is ok. Stay in Play mode and Now press View Mode button to go to EVF only. Now you will only get the played image in the EVF, leaving play you will be back to LCD Only. I.e alittle up side down.
Edited by tjompen1968
