Photo Walk with the Fuji Guys
Details
Come join the Fuji Guys and enjoy photographing the beautiful Toronto CNE Grounds.
Try out the latest X & GFX Series cameras and lenses. Great photography tips and demonstrations
Please bring your own camera gear. Fuji Guys will have a limited number of cameras and lenses for you to try as well
One additional guest allowed per person. Please dress appropriately and wear good "walking " footwear.
PLEASE RSVP: https://fujifilmslatest.splashthat.com/
21191847_10155695375314308_8458220773107
