I have Fujinon XF 23mm F1.4 with X-T2, it is very strange, in video mode, MF is only option, Movie AF MODE is greyed out. In Photo mode, AF is working fine.
if I put XF 35mm F2 lense on, in Moive AF Mode I can choose AF or MF, AF is working fine.
so I am thinking there is nothing wrong about X-T2's setting. it is about XF 23mm lense, is this normal?
