     We've rented a house in Bryson City, NC for the upcoming solar eclipse. I was going to use my X-T2's to photograph it. The start of my plan is the 16-55 set on timer to record the entire transition, and a longer lens to capture the sun.
     Question 1. I've read conflicting reports about using a mirrorless camera for capturing a solar eclipse. Some say it's ok, others that I'd burn out the sensor. I have the proper solar filters for both lenses. Anyone have any experience with this?
     Question 2. Any thought on the settings to use on the  intervalometer to capture the moon crossing over the sun? This kind of thing https://www.cnet.com/pictures/amazing-photos-of-solar-eclipses/18/
     Question 3. General settings to use on the telephoto? (choice of  50-150, 100-400 1.4x, 2x)
I promise not to like my own post.
Thanks !
Warren
