Hi there,
The other day I was trying to assign the ISO switch to the front command dial button (Fn2), in order to change ISO from the front function button.
But it seems this is not possible:
http://fujifilm-dsc.com/en/manual/x-t10/button_fn/edit_fn-button/index.html
Is there another way to assign the ISO to another function menu other than the selector function menu on the back of the camera?
It would much faster to use a command dial button to scroll to the ISO values, rather than pressing the selector and then choosing the value.
Hi there,
Right I have set my XT-10 to change ISO from front button/Dial
Step 1 - enter Blue Menu 2
Step 2- Button/Dial Settings
Step 3 - Command Dial settings - Set to ^F v S.S
Step 4 - Change Fn2 to ISO
So Now, the Rear dial changes Shutter Speed 1/3 stops
Front dial when button pressed brings up iso menu and dial left/right changes ISO value
Unfortunately you need to press the dial in before you can change ISO, but hope this helps
