Hey everyone I had ordered my first X100T from B&H about 2 weeks ago and I loved everything about it.
However i started to notice a slight issue with the LCD, As I was messing around with my menu dials I started to see some jittering on the right side of the LCD panel. I then ever so slightly touched the right side of the panel and it would make the lcd jitter. It seems as if there is not enough space between the panel and the outer casing of the lcd.
Anyways B&H sent a return label to do an exchange.
Today I just got my replacement from B&H and it seems to still have the same screen jitter issue.
The camera has a completely different Serial Number so was a complete exchange and not a repair job.
Im starting to wonder if anyone else out there has this issue and hasn't even noticed it.
Could it be fuji has sent out a bad batch?
Let me know if your copies of the X100T have this.
I hate to be without the camera for another 2 weeks.
But I may as well keep trying to get a unit with out this issue to reduce problems later down the line.
Ive attached a video link down below so you can see the issue.
As you can see im ever so slightly touching the LCD screen and it jitters, it only does it on the right side of the panel and not the other sides.
Thanks again to all those who comment and read my posts.
you can check out the video here
