Update request X-S10
All three of my bodies (X-E2, X-T4, GFX100S II) have shoot without lenses enabled and they have all had it set since I bought them.ย No harm in it at all. Just remember to set the focal length when you fit a manual lens with no electronics otherwise the IBIS (if you have it) goes nuts. I regularly use vintage film lenses from Minolta, Zeiss, Mamiya, Rollei and others on my X mounts along with more modern manual focus stuff from TTArtisans. I also use Nikon AF-S lenses with a Fringer so the world is your oyster! Vintage lenses can be an absolute bargain too - For example the Zeiss 135 f/35 in M42 is as cheap as chips and very sharp as is the excellent Minolta 35-70 Macro (which is also rebadged Leica).ย -
By Neil Rosenberg · Posted
By Tschortschli · Posted
In reply to the original question, it all depends on what you mean by infrared.ย If you mean "see thermal information", then I agree with the comments here.ย However, if you mean near-infrared, the X-T4, or basically any digital camera can be modified to "see" it.ย Check out Lifepixel.com and Kolarivision.com for more info. As regards lenses,ย I'm not exaggerating when I say that I have searched with great vigor (and at great expense) for a way to capture IR images with a Fujifilm camera for which I didn't have to use major amounts of sharpening to bring out the best. Zooms, primes, Fuji, Tamron, Viltrox, Sigma, Zeiss ... probably 20 lenses all told. Plus multiple IR converted Fuji cameras, X-T1, X-T3, X-T5. I even tried different ways of filtering IR, such as using the Kolari clip-ins and lens-mounted front filters. I was ready to give up until I almost accidentally tried one of the cheapest lenses out there -- the little TTArtisan 27mm F2.8. No hotspots that I could see, and best of all ABSOLUTELY SUPERB SHARPNESS across the entire frame. It's this attribute that I search for, and until now, never achieved. In my prior attempts, I listened to the advice from the "pundits", picking up a copy of the venerable Fuji 14mm F2.8, the Zeiss Touitt 12mm F2.8, Fuji 23 and 35mm F2.0, even the very similar 7Artisans 27mm F2.8, and none of them come even close to the TTArtisan for edge sharpness in infrared. Incidentally, I'm using a Kolari 720nm clip-in filter. Sure the TT has its issues -- vignetting at 2.8, tendency to flare with sunlight nearby, but all in all, this lens is glued to my X-T5 for now. This image was taken hand-held with this lens -- completely unedited! -
No - I donโt think so - it means you can take pictures if you remove the lens completely - but Iโm not sure that is a problem
