 A short while ago, I bought a GFX50SII from an authorized dealer and a 35-70 mm lens, and I have a noticeable anomaly in the photos I took. I have cleaned the sensor, done pixel mapping, the camera has not experienced any drops, bumps or liquid contact. I would be glad if you can help me with the cause of this problem. (I have added photos to showcase the issue)
yaşıyorum.
Edited by savas solak
Dil seçimi
    • It appears that Apple now (at last!) fully supports FujiFilm Lossless and Compressed RAF files. In the latest updates of MacOS Tahoe 26.2, iOS 26 and iPadOS 26 compressed files are supported in Finder/Files and the Photos app. Good news for those of us with Macs and iPads.
