Greetings X Photographers! I have the awesome X-H2, for landscape, product and macro photography. I also have a very old Vivitar 283 Auto Thyristor flash. Based on my research, I believe that this flash has a higher trigger voltage that makes it incompatible with the much newer X-H2 hot shoe. However, has anyone ever used it in sync mode (off camera) with another flash or Fujifilm Flashpoint R2 Transmitter? Thanks!
