I’ve never had this issue until yesterday, but all of a sudden my xt-20 is taking black frames, and it doesn’t matter what settings I have it on. I haven’t accidentally knocked the aperture to f16, or accidentally set it to 100 iso. It doesn’t matter if the camera is in ‘auto’, or in complete manual. What could be causing this? I re-format my sd card last night on the computer, and still no luck. Every photo is just completely pitch black.
any ideas?
thanks in advance!
