... if X Raw Studio would be able to use custom profiles across Fuji cameras?
  • Thereby rewarding the most loyal customers who have more than one camera of the Fujifilm universe.
  • Making their lives much easier with having consistent profiles across Fuji cameras, without the need to set-up and manage individually for each camera.
  • Where it would be totally OK if this feature would be limited to shared settings only.
Wouldn't this be wonderful, and such an obvious improvement.
Best
Christian
Hmmm ...
The custom profile files created and stored by XRawStudio look pretty similar. The whole structure of the files is exactly the same at least for X-H1, X-T4 and a X-H2 related (so, 3 generations).
Just the values for camera and serial# are (certainly) different. And features/values that do not exist for an older camera generation are left empty there. That's all.
E.g. if I take a custom profile file created with XRawStudio for the X-H2, and I copy it to the X-T4 folder and just edit the camera and serial# information with a simple text editor ... this manually adjusted X-H2 custom profile perfectly works with the X-T4 inside XRawStudio.
As the underlying data structure seems to be very much the same and data are considering camera differences already, it cannot be rocket science to allow XRawStudio to manage custom profiles across cameras, even across camera generations.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
