I have PSE 10 on my Windows 10 desktop and would like to be able to use this program to work on RAW files taken with my X-T10 camera. How do I go about this?
I've read about downloaded an add-on called Adobe Photo Raw but I'm not sure if this is the best way? Also there doesn't seem to be a direct link on the Adobe web site to download this?
Help/advice appreciated, thanks.
The version of Adobe Camera Raw (ACR) working with PSE is quite old - v.6.5 and doesn't support Fujifilm RAF. So you may use internal (in camera) RAW converter, free Fuji RAW File Converter EX 2.0 (RFC) or any other external RAW converters but no one have any intergration with PSE.
