Hi folks,
I had the opportunity to take some pictures of this beautiful Euroasian scops owl, the smallest owl in Spain. The picture was taken in Guadarrama National Park in Madrid.
Hope you will like it!
Check out my site here: www.josecarpin.com
Fujifilm X-T2 + XF100-400mm f4.5-5.6 R LM OIS WR
