Hi folks,
Last weekend I spent a couple of hours taking pictures of the Manzanares river in La Pedriza Nature Reserve in Madrid.
I am very happy with my XT-2 and the XF16mm f1.4, both are an stunning photographic synergy.
You can check my site too: www.josecarpin.com
These are the results:
Fujifilm X-T2 XF16mmF1.4 R WR ƒ/5.6 shutter speed 79 ISO 200
Fujifilm X-T2 XF16mmF1.4 R WR ƒ/5.6 shutter speed 95 ISO 200
