Frame rate drops after ~4 minutes when using as webcam
Hi, I would really appreciate if someone could answer this question. Is it possible to have the X-T4 shoot in AF-S for photo mode and AF-C in video mode while the front lever is left at AF-S? If so, how would this be done or wher in the menu system would I set this up? This is similare to setting the apeture at f/2.8 for photo mode but fioming at f/4 in video which I already have setup. Thanks and kind regards
According to the manual you can assign auto ISO to any one of the function buttons but I've never tried it. (It's not something I frequently change so all my function buttons do other things.)
Hello, I have a new xt5 and have enjoyed its setup, until now. I hope someone with patience can help me through my ISO dilemma. My question: I have assigned settings for Auto ISO 1,2 and 3. Should I be able to select Auto ISO 1, 2, or 3 for a shot? If so, how? Or is the camera supposed to. At present, my screen shows Auto ISO 3, and never changes. I assigned ISO to the rear dial to no effect. Of course, when I half depress the shutter button is see the actual ISO in real time, but the function of the Auto ISO and how to control it has me confused. Thanks for any help.
By Astigmatism · Posted
FWIW I found that with my 3 Fuji cameras and my iMac, I had to use one of the USB ports on the back of the computer, directly. Going through a USB hub would not work. Not sure, but I think it was somebody here that suggested trying it. -
