Dear Fuji-friends. When shooting in fine or normal image-quality with my x100t, I somehow get a "red"-ish flair on the pictures. No matter what film simulation i choose. The raw version of the same shot, is exposed normally. I am really struggeling finding the answer. Anyone having knowinghow to solve this, and what to do?
Thx in advance, and sorry about the poor english.
